honeywell t6360c wiring
Discussion in 'Electricians' Talk' started by lopezsan, Feb 12, 2024.
  1. lopezsan
    lopezsan New Member
    I'm wiring a thermostat to control a heating mat. There's 6 connection points.
    The mat has live and neutral lines.
    How should this be wired please?
  2. techie
    techie Screwfix Select
    Hang on, I'll just get my crystal ball warmed up.
    Deleted member 320418 likes this.
  3. A photo of heat mat or wiring diagram might be useful. Perhaps the make and model of heat mat too.
  4. MGW
    MGW Screwfix Select
    Unless Raychem or the like, the thermostat will have a place for the probe so the mat does not overheat. So you should have line in/out, neutral, earth, and two for probes, so at least 6 on the thermostat when three on the mat. Also likely neutral and earth are designed for multiply wires.
    The Honeywell T6360C seems to be a standard thermostat not one designed for under floor heating. Nearly all UFH thermostats are electronic in some way.
