If i would like to put several sockets (multimedia, network and electricity) on a stud wall, I need to drill holes on almost all studs for cabling. Whats the maximum diameter of conduit that I can run horizontally through all the studs in a wall at socket level. And whats the maximum number and minimum distance between conduits if there are several conduits horizontally? Is there a special noggin arrangement to maximise the hole diameters on studs?
To my this "drilling holes in studs post", many viewers but no reply yet is it because I post it in a wrong forum or the post not clear enough? Any help, advice would be appreciated. Thanks
