Horizontal wiring in stud walls.
Discussion in 'Electricians' Talk' started by roughneck, Nov 16, 2018.
  1. roughneck
    roughneck New Member
    Hi guys,
    I'm building a garden room. I installed a armoured cable into the base plate went with the water pipe. I ran the cable to the opposite corner horizontal. Is this bad practice. I also ran all the sockets horizontal. Do i need to re-wire the sockets? It is behind the Kingspan. This would be a pain but can be done. But moving the Armoured cable would be a right pain unless unless I fit a junction box in the wall and send a cable up and back down. Wanted to get ahead before a got an election to install the consumer unit.
    thanks for any help
  2. Bazza-spark
    Bazza-spark Screwfix Select
    As you are installing a new circuit this is notifiable work. What does your electrician say? Who is going to sign off this work?
    Kind regards
  3. roughneck
    Not got one yet. Just wanted to get most things done first. I didn't consider it at first with it been armoured cable and the socket cable being over 50mm from the front.
  4. Bazza-spark
    Then you will probably have to rip it out and start again under his supervision.
    Unless you are going to chance it!
  5. Isitreally
    Isitreally Super Member
    Or stick a plug on the other end and call it an extension lead.
    DIY womble likes this.
  6. Rulland
    Rulland Screwfix Select
    How many times?, when will Mr DIY realise?.
    KIAB and Sparkielev like this.
  7. retiredsparks
    retiredsparks Super Member
    Lets hope the muppet electrocutes himself......
    RS
  8. Isitreally
    Why??
  9. roughneck
    Thanks for the help guys. Should of known not to ask for help off a sparky.
    DIY womble and retiredsparks like this.
  10. retiredsparks
    Because he is taking the pee...its illegal, its dangerous...he is a chancer... it's notifiable..its new work.
    Doing you guys out of business that costs you 3 grand a year just to start on 1st jan every year........
    Shall I go on ?
    RS
  11. retiredsparks
    That's right, we just love incompetent DIYers,, chancers and pee takers trying to bypass the legalities of Part P, safety, home insurance and doing local sparks out of work.
    Go and train for 5 years ...run a business in this climate ...and then see if it's a good idea for some muppet to ask these question.
  12. roughneck
    Like I said I was just running wires for an electron to come when I could get one. I suppose none of you sparkys do any joinery work at home do you.
  13. retiredsparks
    Yes we do, ...............and glazing, plumbing, central heating, decorating, appliance repair, floor laying, kitchen fitting, tiling and bathroom renovation.
    But that 'aint going to kill anyone...cos we know what we are doing. PLUS none of that is illegal to do.
    Why do you think Part P was introduced ?
    ..Why do you think our test gear alone runs at about a grand a time ?
    So you are a chippy and don't know any sparks to get advice from BEFORE botching up the job ?
    Well done Einstein.
  14. JP.
    JP. Screwfix Select
    Strewth..
  15. longboat
    longboat Screwfix Select
    It's your shed. Your property.
    Do what you like.
    The swa is mechanically protected so can in effect be run wherever you want.
    I would advise getting a spark in to ensure it meets OL, impedance and VD requirement though.
  16. retiredsparks
    JP ?...have the tablets worn off ?....you are awake.
    RS
  17. Comlec
    Comlec Screwfix Select
    I am very happy that so many DIYers have been 'doing electrics' over the years. Sorting it all out for the new owners of their handywork is good business.
  18. Comlec
    With the proviso that you comply with current building regulations:):)
    longboat likes this.
  19. spinlondon
    spinlondon Screwfix Select
    No let’s not.
  20. JP.
    JP. Screwfix Select
    Lol..hows thing going RS? I trust you are all well m8
