Horseshoe Wedgepackers
Discussion in 'Carpenters' Talk' started by Possom, May 23, 2018.
  1. Possom
    Possom Member
  2. KIAB
    KIAB Well-Known Member
    They are for leveling up & packing out & stay in place, several types of shims & packers available.
    You can get horseshoe packers same size as timber your using, like below.
    Possom likes this.
  3. CGN
    CGN Well-Known Member
    Possom and GoodwithWood like this.
  4. Possom
    Possom Member
    What I don't understand is what the levelling, packing and staying in place is exactly.
    Never having attached a door frame before (it's to an external brick shed) I'd just have presumed I would screw the frame directly to the wall. At the moment I don't understand precisely what I'd be doing with such wedges, or if I require them?
    Are they used where the brick wall is not completely vertical and you want the frame to be vertical? Is that what they do?
  5. KIAB
    The wall your attaching door frame maybe of true,so when you fix your door frame you will pull it out of shape,when tightening up fixing,so any door fitted to frame won't be square in the frame & therefore jam in the frame.
    Possom likes this.
  6. Possom
    Possom Member
    Do you mean pull the brick wall out of shape (and therefore the frame also), or simply the frame?
  7. KIAB
    Trying to post a You Tube linky & failing, as pc is playing up.:mad:
    You can't pulled a built wall out of shape, but you can build a wall that isn't straight, bows in/out
    ,then when you come to fix a door frame/window to opening, or a door frame to a wall, you have to sometimes pack it out to square it up,(plumb & level) , otherwise say a door won't fit squarely within a door frame,you might get a tapered gap at top,etc.
    Possom likes this.
  8. Possom
    Possom Member
    The brick wall in question is decades old. If I find that it is indeed completely vertical, would that mean I could then attach the frame directly onto the wall without the need for wedgepackers?
  9. KIAB
    Yes.:)
    Probably built truer than a lot of the walls today.:D
    Possom likes this.
  10. Possom
    Possom Member
    Ah, okay.
  11. Astramax
    Astramax Well-Known Member
    What happened to home made wooden wedges and spacers...........those were the days :)...................... seem's like everything is 'off the shelf' today.:(
    Jord86 likes this.
  12. Beeero
    Beeero Member
    Dpm and hardboard used to be my favourite where folding wedges were to big
  13. DIYDave.
    DIYDave. Well-Known Member
    The thing with the plastic wedges is the cut out ,ie horseshoe shape
    If wall is out where you need to put a fixing, drive screw partially in then slip wedge between wall/frame and slip over screw, then fully drive home
    Also loads of other uses, good when fitting skirting board to level up then just remove and reuse
    More uses, just can’t think now
  14. WillyEckerslike
    Tiling above a bath. Crucial that the first row is dead level but some baths I've installed have not been exactly flat along their length. Different thickness packing pieces are really useful. They also help to leave that desirable gap to allow you to get a sound silicone joint/seal.
  15. Pollowick
    Pollowick Well-Known Member
    Not quite. With those wedges, which are tapered, you insert one from each side and the ride over each other and lock together giving good control over teh exact thickness.
    WillyEckerslike likes this.
  16. KEVIN NAIRN
    KEVIN NAIRN Member
    The horseshoe packing used to be called "trouser shim" (as it looks like a pair of trousers) it's for shimming or packing behind a frame to make sure the frame is plumb (vertical). It should be used with a long spirit level (say 1800mm) or a short level taped to a DEAD STRAIGHT wooden batten. You screw the frame to the wall (screw to the brick or blocks, never the joints) and offer the level to the frame. If there's a gap between the frame and level, or if it's out of plumb, you undo the screws a few turns, place the plastic shims behind the frame and tighten up the screws. Yes it's a fiddly, tricky task but vital to ensure the frame is plumb and the head of the frame is level (horizontal). The right way is to shim the frame at the top or bottom, depending which way it's out of plumb, then shim in-between (using the level as a straight edge). When finished, the frame should be plumb and straight with no bends in it. The frame should be plumbed both ways: from the front AND side. Don't like locking wedges as they are a pig to remove or if the go in too far.
    Builders' dictionary:
    Plumb: Vertical; Level: Horizontal; Square: 90 degrees (a right angle); Straight: shortest distance between 2 points; Flat: not curved or wiggley (a flat roof is flat but has a fall, it slopes)
  17. Paulie1412
    Paulie1412 Active Member
    Pretty sure flat, square,plumb and level aren’t in most builders dictionaries
    Jord86 and WillyEckerslike like this.
  18. KEVIN NAIRN
    KEVIN NAIRN Member
    Nice one!
