I am looking to replace my heating and hot water controller with a smart controller. I basically just want to be able to turn my heating on from my phone. I currently have a Horstmann H27XL programmer, as shown in the attached photo, a Bermuda Baxi boiler and a hot water cylinder which is in a cupboard upstairs. I’m not sure which controllers will be compatible with my system so any advice would be greatly appreciated. I’ve looked at Hive and Google Nest but I’m just not 100% sure they would work with my system. Thanks in advance, Paul
Hi The hive type of system has two main parts, it replaces the programmer and replaces the room stat, when the programmer is removed and the new hive is fitted, and the room stat, (battery powered) They both link to your home internet system , you can’t adjust the hot water temp, as far as I understand, but can adjust the on/off for hot water, And of course, have full control of the heating time and temperature regards Peter
