Hose query
Discussion in 'Car and Van Talk' started by Mark63, Jan 30, 2020.
  1. Mark63
    Mark63 New Member
    At present I’m connecting an outside tap by the short hose to the reel which has a 15m hose of which I connect into my pressure washer (this being the norm I would suppose) but my question is would I be able to do this in reverse ie
    Have the short hose connected directly to my pressure washer from the reel in my van and the 15m hose coming from my van which will then be connected to a customers outside tap.
    I don’t see this being a problem myself as it will be exactly the same distance the water will travel also the connections on each end are the same I suppose my question really is regards the short hose from the reel to the pw and whether it would affect the flow.
  2. Severntrent
    Severntrent Screwfix Select
    No difference whatsoever, same length of hose, same number of fittings/connections so same frictional resistance from tap to pressure jetter whichever way the water is flowing.
  3. Mark63
    Mark63 New Member
    Thanks as I thought but just wanted it confirmed
