Guttercat. Happy new year mate, if it is to hot yes it can. And has been known, I always use just lukewarm water and never had a problem. Potty.
Happy new year to you Potty. Yer a true gent Potty. Never had a prob with hot water on iced up windscreen either.
1. start the engine 2. turn on windsreen blower 3. retire to house for a cuppa 4, 15 minutes later drive away, p.s don't forget to lock van/car door with spare key,
A lot of modern diesels won't heat up on idle and also kills modern turbo diesels being idled from cold as oil pressure low - best clear as much as you can then start and drive immediately.
Constantly using water to defrost the screen often results in things getting frozen - like gear linkages, cables etc.
I got rid of my screen as Im so fed up with de-icing Only problem now is iced up eyes one mile down the road
I always use hot water, and never had a problem. Has any one had a poroblem?, or do you KNOW someone who has had the problem (as opposed to as freind of a freind etc)
My wife say's she never has a problem defrosting my windscreen or warming the drivers seat before i go out.
Constantly using water to defrost the screen often results in things getting frozen - like gear linkages, cables etc. You had best not go to the UK then with your car. You will constantly have rain water getting on things.
