Hi. We recently bought a new build house (show house which was build 4 years ago but never been lived in). We viewed it on weekend and bought as first-time buyers, so not experienced at all. It was pretty quiet, and the main road is about 50-60 meters away, so it seemed fine. However, after moving in, big heavy lorries are driving past at 40mph and they shake the house significantly (24/7 waking me up serval times a night). The developer probably filled all of the cracks inside however the outside has cracks like attached. Please note our house is the ONLY house with the cracks as we just walked the whole area to check if it is just us. We are also the closest to the road compared to the other houses. The dream of the first house is becoming a bit of a nightmare.. We contacted the council to check the state of the road and look into lowering the speed limit to 30, but not sure what else we can do. The house is lovely but after only being here two weeks we are starting to regret buying it.. We are afraid it will make the house collapse in few years
Did the surveyor not comment on the external cracks? The one which goes through a block is more of a concern, but neither are great. I would get back to the survey company and see what they actually said in the report. The house should be covered by the builder, but it’s not what you want to hear on your new home.
Hi, Looks like is been repaired before ? The pointing looks different, you probably need advice on this , not from someone in a bar ! good luck
I'm not sure. We had the valuation done by the lender but we never received a copy of it. It was our first house so didn't buy an enhanced one which we should and its a lesson learned the hard way The cracks in picture 2 are on all 4 corners. We have 2 year warranty on it, but the developer will probably just fill the cracks which is not the actual issue (the house shake is). Would it be worth getting a snagging survey done now or is it too late? We basically bought a ticking bomb and can't do anything about it anymore?
I did think this too I don't recall seeing the cracks in the first place especially on the front of the house.
Hi You may be able to an agreement for an insurance backed guarantee from the builder/ seller, ? Action is needed now, Contact solicitor,, with your concerns
I've tried contacting my solicitor however they said they only can support me up to completion and I'd have to pay them to take the case for me.. Agreement to get this fixed? I think I should be able to achieve this with the developer directly ?
Hi. Yes first home you are worried about more things than problems like this But I would keep pushing. On the first Pic where the edge of sloping roof is shown. TOP left corner is that one of these Metal rafter ties showing thru the pointing? I am not sure if thats the correct term but you guys will know what i mean. Builders are so rough now. No pride. Best of luck Newbi
Thanks you for all the advise I'll try to get as much info tomorrow as possible. what would you say the best scenario solution would be for me ?
I would suggest structural survey. If that reveals anything fundamental then you may have a claim from the developer but I suspect that won’t be easy to pursue. First off get the survey done
Thank you again. I'm completely useless at the paperwork side of things. I'l get thing arranged asap.
I’m no building expert but surely 50 to 60 metres away is far enough from the road for any structural problems not to be linked to the road. Especially as you bear in mind many houses are built a lot closer to main roads than that. But as I said I’m no expert. Really hope you get a satisfactory solution sorted.
Is there no NHBC warranty?? Should be 10 years though I guess an argument could be made that there's only 6 left. Get a structural survey done now. They look like structural cracks rather than shrinkage.
There is 2 years from the developer and 10 from NHBC (so they said). I know we have home insurance, but not 100% sure what's included will have to have a good read through it tomorrow. Because of the distance from the road, we would never think the house could experience any issues apart from the noise. We are so gutted, as we had to change jobs, moved to a completely different shire just to afford a house and now this.. Can anyone recommend any good structural survey company in Lincolnshire?
