How do I get to the washer??
Discussion in 'Plumbers' Talk' started by lizzy_dripping10, Aug 12, 2019.
  1. lizzy_dripping10
    lizzy_dripping10 New Member
    How do I get the head off to replace the washer, please? 20190812_101446.jpg
  2. gas monkey
    gas monkey Well-Known Member
    look at the back of the tape grub screw undo lever off
  3. Heat
    Heat Well-Known Member
    If no grub screw at back of that tap head, which is highly likely I reckon with that tap, - then it pulls off vertically.
    But might need a bit of strength to do so.
    If it doesn’t budge it might be possible to lever on opposite sides under the head with 2 flat blade screwdrivers, carefully doing it to avoid damage.
    If the tap head is quarter turn on/off type, then it is ceramic disc works and not a tap washer type. Ceramic works normally have to be fully replaced but not always easy to source exact type
    lizzy_dripping10 likes this.
  4. gas monkey
    flick the coveroff the side may shed a bit of light on the job
  5. just pumps
    just pumps Well-Known Member
    Another photo please say around 12-18" away this time. Or a couple of photos.
  6. gas monkey
    is that a screw at the front or just somthing on the persons leg looks like a couple of scrackers as if its been tried
    The Teach likes this.
  7. koolpc
    koolpc Well-Known Member
    Dynamite
    PhilSo likes this.
  8. gas monkey
    or maybe a new tape mr k really you heavy handed person:D
  9. Astramax
    Astramax Well-Known Member
    No wonder you can't get it off, someone is holding onto it.:D
  10. The Teach
    The Teach Well-Known Member
    photo in #1 is more of a selfie,
  11. DIYDave.
    DIYDave. Well-Known Member
    Like those funny mirrors at the fair ground that either make you look 2 feet tall and the same wide or 8’ tall and like a beanpole
    My missus looked in the former type once and asked me ‘how do I look’ ?
    You can guess my answer and your right, it didn’t go down too well :eek:
  12. gas monkey
    does my bum look big in this/ yes the same as all of them cos you have a fat ar. ouch sorry dear
  13. Heat
    Best reply to does my bum look big in this? is, -
    “Hold on until I take a few steps away to be able to take it all in”
  14. DIYDave.
    I’ve gotta disagree with this ‘best’ reply Heat ........
    Mine would simply be,
    Does my bum look big in this ?
    It is big ........,,,
    Simple
    Factual
    To the point
    Dangerous :eek:
    Heat likes this.
