Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hi - doesn't look like the plasterer's going to return to put back the light fittings.
How do I do this please?
Thanks.
At least they didn’t plaster up to it
Not sure if you read terrymac’s post, but he outlined what you need to do. The two cables to the ceiling rose you can just carefully push into the hole.Do you know how to put them back?
Thanks
Thanks
Thanks - patchy wifi here - I didn't see your post!Turn off mains power at your fuseboard or consumer unit. Remove the white cover by unscrewing it from the base of the ceiling rose. You will see two holes in the base for fixing screws ,and the base gets screwed to the joist in the ceiling. Be very careful not to damage the cables when putting screws in ,and ensure both screws go into the timber joist ( you should be able to see the timber through the hole in the ceiling)
Sorry - planning on doing these this weekend - do I need rawl plugs or just longish screws? Thanks!I don't know whether this helps. The ceiling rose should be in 2 parts which unscrew from each other. One part is fastened to the ceiling and other screws back over it.
You are also complaining about a plasterer, and asking how to refit an electrical fitting in a plumber's forum. . .*** - I hate DIY
Don't do it then. Call the plasterer back. Have you paid him/her?*** - I hate DIY
