Having made a fitted shoe cupboard, found the sprung hinges are putting too much pressure on the joints . (you will see in photo it is just a frame with material stretched across it, there are dowels joining the joints) Thought the solution might be to remove the spring from the hinges to take the pressure off the joints but don't know how to get the spring out - any help would be very much appreciated. thank you
