I am subscribed to a free trial of a site that gives you the opportunity to quote for jobs. It really is a waste of time as none of the jobs give enough detail to formulate a proper quote. One of the best examples is this:- Description of the work to be carried out: Driping taps in the bathroom: I would like to chang to a new set of taps which I have already. Also the hot water center valve broken needs replace, I can,t sut the hot water...,and the cold water center valve is a bit stiff, may need replace. Give me an estimate first, I don't pay per hour. Now just how much would you quote for that? Tony
Way too much and if they accept you are OK. Seriously though, some of these websites are in cloud-cuckoo land.
Quote £300 plus the VAT. Sounds like a couple of taps and two service valves to me. Although it could be bath taps which bring their own nightmares. I think it's the basin.
> Sounds like a couple of taps and two service valves to me. Although it could be bath taps which bring their own nightmares. I think it's the basin. always best to hedge your bets
Avoid like the plague. Where quote is a fixed price you run an unnecessary risk of losing money and time. Changing bath taps (thinking cast iron bath , red lead putty etc)with the far tap a mile away on 3/4 pipe can take forever.Even changing a 22mm cold feed gatevalve can be tricky. I'd rather not risk a blind quote.
I have heard of someone who ended up moving a cast iron bath to get enough access to change the taps! Tony
I have heard of someone who ended up moving a cast iron bath to get enough access to change the taps! Tony I'm really glad I'm not the only one who's had this problem.
