I know it's a bit 'finger-in-the-air' but just looking for an approximate idea of cost. The render on the outside of the house is in pretty poor shape. I think it probably needs removing and starting again rather than patching. It's less than 10 sq metres, most of which is above the flat roof. The remainder is above the front door and would require scaffold (or ladder?). Is that enough information for any meaningful response?! thanks.
"Is that enough information for any meaningful response?!" On this forum ? You must be joking ! You need to give your neighbours NI number, your mum's shoe size and the current GDP of Sri Lanka before the "How-long-is-a-piece-of-string"'ers will even read your simple, straight forward question on rendering. All together now... "MORE INFORMATION NEEDED !!!
