I have cavity walls with concrete breeze blocks externally and Thermalite Aircrete bricks internally. We have attached 75mm Recticel PIR insulation boards to the walls using mechanical fixings, to make it strong and robust. Here is a pic of the insulation not attached. Next stage will be to put a vapor barrier on the insulation boards which is foiled. However I have not thought about the next step, which is how to fix the plasterboard to insulation boards. I've seen video on Youtube with someone using Pinkgrip Dry Fix foam? However I am skeptical foam will hold. Is there a special dot and dab mix you can get that will stick to foil? Or should I put a small frame with 25x50mm batten between the insulation boards and then fix the plasterboard to that? Any advice or suggestions welcomed.
This has been discussed on the Eco board https://community.screwfix.com/threads/make-own-insulated-plasterboard.250605/
It only has the barrier on both sides! I agree with you but the OP could be talking about bridging shielding the open/cut end of the PIR to the window frame in the picture, before affixing the plasterboard. There is little room for vapour barrier PIR to fit across the gap. The OP would have needed to have considered this before ordering windows plus frame spacers if PIR was to be used for the recess return, so may now have uninsulated window aperture.
This is a renovation of an extension built in the 70s. Its coastal and some of the cavities are, well, not great, built by locals Rooms are massive so I am trying to shrink as much space to heat as possible. I think I will do batten frame between the PIR and PB. All walls will not be load bearing, just sockets.
Presumably there is an unmentioned 'something' to space the PIR from the wall (there's a gap in the pic). OP - did you cut the PIR with a chainsaw?
There's some bridges in the cavity, until I get some waterproofing externally there will be damp coming in. You can see in the photo around the window opening Im reluctant to put stud partition that would rot in that situation being fixed to the cavity wall, especially putting PIR boards between it and the breached cavity wall. I cut the PIR with a Bahco hand saw for fine cut, but will use a stanley blade in future.
nothing wrong with using a hand saw, I didn’t see any issues with your cutting. If you were worried about damp, then you could have put a dpm on the wall before attaching your battens/lath. Doing it this way, you could have straightens and plumbed up any discrepancies with the brick work before fixing the pir and Pb.
