how to calculate wood joist size
Discussion in 'Carpenters' Talk' started by siraz, Apr 28, 2008.
  1. sinewave
    sinewave Screwfix Select
    Ideally all joists should sit on a wall.
  2. siraz
    siraz New Member
    Hi Sinewave,
    He is going to support the joist along the width of the wall on the party wall, so the end of the joist will sit on the either side of the neighbour wall, i am sure these party wall are only single brick am i right ?
    Then he was going to place the metal joist hanger which the joiner told me to order Jiffy hanger 2"inch and he place the joist on these 2"inch hanger and the joist will rest on these metal hanger.
    I dont mind if he does that, as long it is strong and hold the weight of the joist and other weight, like it will partition upstair in the loft to cover the chimney and other open brickwork.
  3. WillyEckerslike
    Alan. ECM hasn't been around for years so is unlikely to see your request. Furthermore we get some mindless trolls on here so if you still have time to edit your post I would remove your email address.
  4. Alan Roche
    Alan Roche New Member
    Deleted. Thank you
