How to fix a crack along shower tiles?
Discussion in 'Tilers' Talk' started by Azzamean, Feb 12, 2018.
  1. Azzamean
    Azzamean New Member
    I've just purchased a new flat and plan to makeover everything eventually.
    I've noticed that the shower has a few cracks along some tiles.
    https://imgur.com/pUOXH8K
    https://imgur.com/KMLzpaV
    Though I understand there there could be water damage. **I don't want to replace any whole tiles yet**...
    Is there anything I can use to fill in the crack to at least make it waterproof?
    Went to screwfix and was recommended to use this. But I noticed it says grout?
    https://www.screwfix.com/p/mapei-waterproof-fix-grout-white-1-5kg/64982
    Would this be suitable to spread over the cracked tile. And then wipe over with a damp cloth to even it out?
  2. DIYDave.
    DIYDave. Well-Known Member
    Understand that this is a temporary repair but grout needs a decent depth (full tile thickness) and width (maybe 2mm) to give it some strength. Looking at pics, don’t think ur gonna get much grout in the cracks
    Think as a temporary fix I would use clear or white silicone. Really force silicone into crack using a plastic scraper and remove excess from tile face
    Once silicone dry, this will bond well to tile and form a watertight seal
    Not done this myself but can see it working as a temp fix no problem :)
  3. nigel willson
    nigel willson Well-Known Member
    I’ve used clear stick back plastic b4 as a temporary measure
  4. Azzamean
    Azzamean New Member
    Cheers guys, I ended up using a clear silicone for the job!
