Hey folks, I'm renovating our new house and just removed the architrave around a door to access the cracks behind. The plasterwork was just resting in place and fell out at the first touch. See the photos for a better idea. How do I repair this to make sure that it doesn't happen again? I'm thinking SBR, sand & cement followed by a plaster finish (I'm plastering the wall anyway). Will that SBR allow the render to bond to the wood frame? Thoughts, please? Many thanks in advance.
Brush down to remove remaining loose plaster and dust PVA 1–4 mixed with water, brush on and give damaged area a good soaking - allow to dry Fill ‘gapping hole’ with bonding plaster, smooth off with a float/piece of timber and allow to dry Now ready for skim coat Bonding plaster around £8 a sack, great product, if you’ve got whole house to do up, will have loads of uses for some bonding plaster, just keep remaining plaster airtight and dry as does go off, leading to extremely rapid setting (in the mixing bucket)
Thanks, Dave. Bonding works, I've got a bag open already. In fact, I just packed out around the light switch with it before removing the architrave. Just wasn't sure that it would bond to the wood okay. I'll dig out the PVA tomorrow. Thanks again.
The plaster doesn’t really bond that well to the wood but then again, this isn’t a problem The PVA will help the bonding stick to the dusty plaster repair and help to firm up the area A gap between door frame and plaster will be covered over by architrave anyway so no issue there
Belts and braces ... whack a few unrusty nails into the wood ... one every 10cm or so ... and leave them proud enough for their heads to be set into the bonding. Might not be perfect, but it certainly won't do any harm.
