How Would You Fill These Holes?
Discussion in 'Other Trades Talk' started by HugeWesty, Jan 12, 2020.
  1. HugeWesty
    HugeWesty New Member
    I know I've left the door open for complete smut, but how would you fill deep holes like this? These are from old and now disconnected (done by electrician) electrical interfaces.
    Thanks
    [​IMG]
    [​IMG]
  2. DIYDave.
    DIYDave. Well-Known Member
    Brush out dust and loose debris
    Seal cut out with PVA diluted 1-5 with water - allow to dry
    Fill with bonding plaster, can whack it in at around 40mm depth in one hit, press in well to compact, level off with a trowel or damp batten of wood
    Can also fill with a mix of plaster board and bonding plaster if you have any scraps, just seal cut out as above, bonding plaster, PB, bonding plaster, level off
    From your previous post looks like your having the walls skimmed (?) so finish doesn’t need to be super fantastic at this stage ?
    HugeWesty likes this.
