I'm fitting a Howdens kitchen and I'm puzzled by the door fitting for the 600 horizontal hob wall unit housing an extractor. The door has two cutouts for hinges as usual but they are on the left hand side, very close to the door edge, rather than the long side across the top to allow lift up. I have the flap stay to go with it but do i really need to cut out for the hinges myself when every other door is pre-drilled correctly? The box description seems ok and i have another one above the oven housing with same problem. Am i missing something obvious?
