Hows the best way to mark the points ?
Discussion in 'Engineers' Talk' started by Habeohtjt5555, Jun 24, 2018.
  1. Habeohtjt5555
    Habeohtjt5555 New Member
    Right......... I have a small penny washer 50mm with a 6mm hole in the centre. I want to mark out a small equal sided and equal angled triangle in the centre, the points of the triangle will be drilled with a 6mm drill bit, each point is to be 10mm from the outer edge of the washer, Hows the best way to mark the points ? or work out the size of the triangle ? thanks
  2. dcox
    dcox Active Member
    Hopefully the attached will help. Print it out at 100% and cut and stick it on to a washer and centre punch and drill the three 6mm holes for the points of the triangle. Then I'd use that washer as a template to mark up the others.
  3. DIY womble
    DIY womble Well-Known Member
    Posted at 4 in the morning , someone's had interesting night
  4. sospan
    sospan Well-Known Member
    Clearly a wind up from an ex-member .....
  5. dcox
    dcox Active Member
    Glad I didn’t waste my time then...
  6. DIY womble
    I like to reply to the slimming posts , but I'm getting p155ed off that they don't reply back
