bright_Spark
Screwfix Select
don't talk stupid, been all weekend doing the rail, 3 left then finished.Looks the same
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Well yeah, ddduuughhh I am converting it to electric.OMG have you drilled a 20mm photo cell into it![]()
I would of put the control at the supply end OMGWell yeah, ddduuughhh I am converting it to electric.
Ruined it.Well yeah, ddduuughhh I am converting it to electric.
He might aswell skip it nowRuined it.
What do you mean? It is old meets modern.He might aswell skip it now
Put it at the house end don't ruin the fittingI am converting it into electric so I need a cell on it to turn on and off, all street lights work this way.
You should have had it remote from the light.I am converting it into electric so I need a cell on it to turn on and off, all street lights work this way.
Talk stupid, it has its own cell integrated into the light. You wouldn't understand. This is real world street lighting. Authenticity is key herePut it at the house end don't ruin the fitting![]()
Naah it needs to be as authentic as I can make it. I don't want a replica type. This is how it is done. You cannot see the cell once on the postYou should have had it remote from the light.
Authenticity went out the window as soon as you drilled the hole.Authenticity is key here
Find someone to braze a piece of copper in.How do I fill in a 20mm hole in a copper lantern??
It isn't seen, plus I have to wire it into the other street lights down my street so needs to come on and off at the same time as thoseAuthenticity went out the window as soon as you drilled the hole.
Seriously mate you shouldn't have drilled it, but it's done now like you said it wont be seen.It isn't seen, plus I have to wire it into the other street lights down my street so needs to come on and off at the same time as those
I have to drill it out, I am wiring this in direct to the grid, no other way of control otherwiseSeriously mate you shouldn't have drilled it, but it's done now like you said it wont be seen.
