The answer to the loft insulation nightmare of 15" of rockwool at 90 degrees to the joists with the tank/pump assembly at the far end of the loft. Special super boots with a stud detector in each sole, its just "Beep and step" I thank you!!!!!!!
wonder if thet'd give me 24k for a nice new transporter sportsline t174 as owned by the aga fitter i was working with today?
You're getting confused - which will not be hard for you bampots!! I don't post under any other user name.
