M
Mr Shabby
Guest
As the title states, I never thought the day would come but I need help in the planning of a bank of shelving!
The effect I want to achieve is essentially what will look like 4 x 70/30 split cupboards all at around 500mm wide. I'm ok with attaching the doors but where I need help is firstly with the choice of materials - should I go with MDF, Contiboard or ply for the internals. I may paint the interior but might not so that part can be worried about later.
Secondly, my room is 2.2m wide and tall so I will be having a small plinth at the bottom and scribe some material to finish each side. To build the internals, should I take a 2440 sheet and trim the end off to run it floor to ceiling,? If I do this, each shelf would span 500mm. Would that span be ok with a depth of 600mm made in MDF and if so, what thickness? Or would I be better to run the near full sheet from wall to wall and then glue and dowel upright sections in?
Like I said, I'm ok with the building but I find myself overthinking like crazy!!
Thanks in advance
Scott
Thanks in advance
Scott
