I reckon I've lifted some 1st floor joists slightly
Discussion in 'Builders' Talk' started by fred812, Jun 28, 2021.
  1. fred812
    fred812 Active Member
    Only been in the house a few months. While decorating an upstairs bedroom I found quite a few nail heads raised a mm or 2 so tapped them down. Also put in quite a few 4 x 40mm screws where floorboards seemed a bit loose or squeaky. Now I have a different problem in that a whole quadrant of the floor produces a noise not individual boards. I reckon the joists had dropped in some places and I've now lifted them up to the boards with the screws so the joists aren't sitting on the wall anymore. I'm going to lift some boards and try and find the problem but has anyone got any thoughts on whether I might be on the right track or miles off. And if I am how I fill the gap between the joist and wall please?
    Thanks.
  2. Jord86
    Jord86 Screwfix Select
    Remove the screws and a couple of floorboards in the problem area and take a look. 4x40mm are too small a gauge and length to be effective long term.
  3. fred812
    I can't at the moment, just trying to get a few thoughts.
