Hope you can all help me out Am a gas engineer, mainly installer but now getting into breakdowns. I came across 2 ideal logic plus combi boilers 24kw. With the pressure gauge niddle rattling and making noises not being stable in one in position. A new has been fitted but, still the same problem occurs, customer informed me system had a powerflush. Can I say boiler is newly fitted about 8months ago.any ideas guys or has any one come across this sort of problem. Rads are all bleed and no air lock. Pls constructive answers pls thank you all
Can I say boiler is newly fitted about 8months ago.any ideas guys or has any one come across this sort of problem. Rads are all bleed and no air lock. If you look closely, you will find that the boiler comes with a SEVEN years warranty. So you should be contacting the manufacturer to sort it out for free.
