Ideal Standard H18 - - on display
Discussion in 'Plumbers' Talk' started by Maverick.uk, Dec 4, 2018.
  1. Maverick.uk
    Maverick.uk New Member
    Hi,
    My daughter has just got her new house. Boiler was working ok but a week later we have been presented with 2 dashes "- -" on the display and heating appears not to be coming on.
    System is typical 'system boiler type' with Boiler (Ideal Standard H18, 3 port valve, cylinder, rads etc).
    Ive checked that from programmer the system is calling for heating and or hot water, 3 port valve motors and pump runs, signal present at boiler.
    The manual suggest that dial 'B' is in off position (boiler off) but its not, its rotated to on position.
    Have i missed something or is it time to call CH Engineer.
    Many Thanks
    Kevin
  2. Mike83
    Mike83 Well-Known Member
    Could you confirm the boiler model.
    The Teach likes this.
  3. The Teach
    The Teach Well-Known Member
    They make toilets :(
    KIAB and Mike83 like this.
  4. Maverick.uk
    HI Mike
    From the front panel it Has Ideal Logic+ H18
    Thanks
    Kevin
  5. The Teach
    Could be a number of defects,first check would be to turn it off electrically then power up. Wait 4 minutes and see what happens.
    The mode knob may have a snapped spindle although visually the knob front is pointing in the correct direction the rear part could in an off position.
    Could be a few problems,not ideal :( Easily repaired by an Ideal expert.
  6. Maverick.uk
    Yes, we did this already several times, the old reboot. It goes through its start up sequence and displays as follows:-
    All display items on,
    Displays H
    Displays n
    Displays 18
    Displays 11
    Displays --
    The mode knob feels nice and positive so I don't suspect that, but of course its a possibility and thanks for the suggestion will try and check this.
    Typical its just out of warranty installed about 18 months ago......
    I'm beginning to think its faulty PCB / motherboard.
    Thanks
    Kevin
  7. Maverick.uk
    Engineer coming Saturday so hopeful he can diagnose.
    Cheers
    K
  8. KIAB
    KIAB Well-Known Member
    Do update this thread as to what is the fault.
  9. Maverick.uk
    So the engineer arrived but thought it was the 3 port valve, had already eliminated this as it was giving a 240v back to boiler to say I want heat. He suggested that the port itself could be stuck inside so boiler would fire and shut down quickly, unfortunately this wasn't happening and like i said according to the display boiler was switched off. He took the head off and tried it like that but made no difference.....
    So, i recalled the post above about the switch and with the engineers agreement we removed the PCB and edge connectors and i reconnected the board and sat it on the plastic housing and turned the switch pot with small screwdriver, voila boiler display went from the 2 dashes to displaying the temperature. So either one of the edge connectors wasn't connecting properly or there is something amiss with the switch to turn on and off. We have to revisit the plastic turn switch to see why it's not positioning correctly but left it working for now. Strange that the switch is not actually a switch but a pot (variable resistor).
    Cheers
    Kevin
    KIAB likes this.
  10. KIAB
    Intresting mystery.
  11. The Teach
    commonly called a potentiometer :)
    The rotary mode switch (reset) can get forced,causing the spindle to snap or bend out of position. The corresponding potentiometer can also become damaged.It may be fixable with just exchanging the mode switch knob but for peace of mind the user pcb should also be be considered.
    https://ideal-partnership.co.uk/cms//uploads/documents/8048e6243137f158def25b033206756b.pdf page 48.
    The new logic boiler does not use the rotary mode switch as a reset but use a push button instead ;) progress-
