Identify SFCU
Discussion in 'Electricians' Talk' started by Seelda, Mar 11, 2018.
  1. Seelda
    Seelda New Member
    20171219_121224.jpg My mother in law's flat has a broken SFCU (see picture). Can anyone identify the manufacturer and possibly a supplier from where I can get a replacement?
    Thanks!
  2. KIAB
    KIAB Well-Known Member
    Unscrew it, name will be on reverse side usually.
  3. seneca
    seneca Screwfix Select
    They are standard fitting so any make will fit and work ok, although it won't necessarily match the others.
  4. Seelda
    Seelda New Member
  5. Seelda
    Seelda New Member
    It was finding a matching one that I was after. Sorry, should have explained that.
  6. seneca
    That's ok, they're not expensive so you could change them both if it comes to it.
  7. Sparkielev
    Sparkielev Well-Known Member
    They look like volex fuse spurs not sure they still do them now
  8. Bazza
    Bazza Well-Known Member
    They do, but the appearance is slightly different.
    [​IMG]
    Click the image
  9. Sparkielev
    Yeah you right
  10. masterdiy
    masterdiy Active Member
    Replace all 3. its only money. £18 max.
    Bazza likes this.
  11. robertpstubbs
    robertpstubbs Member
    Looks more like Crabtree to me.
  12. Bazza
    @Seelda
    Trying to help you. Can you have a look for makers name please.
  13. Dr Bodgit
    Dr Bodgit Well-Known Member
    I'd replace them all with MK Logic, but that's just me.
    masterdiy likes this.
  14. JP.
    JP. Screwfix Select
    Concur replace the lot..:)
  15. robertpstubbs
    A grid switch would have been neater.
  16. JP.
    JP. Screwfix Select
    Concur a grid switch would be neater..however have never fitted a grid switch system so canne say no more..do you have to chop out more wall and stuff?..:)
  17. robertpstubbs
    A 6 or 8 module grid faceplate would be about 146x146mm and the backox about 135x135mm.
  18. JP.
    JP. Screwfix Select
    Many thanks Rob..maybe one day I might have the pleasure of fitting one of those grid switch systems.
  19. Bazza
    That’s a big step from swopping out a couple of tired FCUs.
