Ikea Wood Worktops Join
Discussion in 'Carpenters' Talk' started by marc1977, Feb 13, 2018.
  1. marc1977
    marc1977 Member
    Hi,
    I am fitting Ikea solid wood worktops this weekend. They have a very slight bevel on the edge but not much. anyone know it its best to just butt join them or should i do a proper worktop mitre?
    If mitre is the option I dont have a router or jig. happy to but one although i wonder if its really a diy job?
    Cheers
  2. Dr Bodgit
    Dr Bodgit Well-Known Member
    A mitre joint is the way to go, unless you want the eye sore of a council house joiner.
    As a one off, I'd suggest you find someone local who can do this for you. You'd need a router, jig, knowhow and some patience to do a decent job yourself.
  3. retiredsparks
    look at it several times....
    RS
  4. Dr Bodgit
    It would take me the best part of the day watching this repeatedly to understand 100% exactly how to do it properly.
  5. retiredsparks
    First time ..bit black art...second and third..it just becomes obvious...
    You would have no probs...
    Rs
  6. DIYDave.
    DIYDave. Well-Known Member
    Depending on the style of the wooden worktops, doesn’t a mitred joint look a bit weird, if say worktop is made up of timber blocks ?
    I’ve got Iroko tops (made of blocks, don’t know technical term) and prior to fitting, we looked at both mitred and butt jointed as fitting option
    So pleased we went ‘butt’
    Mitred seems to make the join look soooooo long and matching grain pattern doesn’t always work
    A good fitter and butt jointed needs no ‘council house joiners’ - why would you ?
  7. kitfit1
    kitfit1 Active Member
    A mitred joint from front edge to back corner does look horrendous yes. A Masons mitre done with a router and jig however, looks perfectly fine and is only slightly different to look at than a butt joint. Even more so if the jig is set to a 10mm mitre.
    CGN likes this.
  8. DIYDave.
    Ah ha yep, fair play kitfit....
    Just wondered when op said mitred ....
    Surely not a 1st time job for a diy’er is it - no offence as don’t know the chaps level of woodworking skills
    We all have to start new sometime but on brand new timber worktops ........ :eek: Unless uv got plenty of scrap to practice on ?
  9. kitfit1
    Well, i wouldn't want to tackle a solid wood worktop joint if it was my first time. Even more so when the OP dosn't have a router or a jig.....................my guess is the OP has never used a router either. Solid oak, Iroko and Beech have to be treated with respect when using a router. You can't cut as deep and fast as you would with a Laminate top, or Acrylic for that matter.
    If i was the OP i would take Dr Bodgit's advice a get someone local to do it.
    Astramax likes this.
  10. Longy75
    Longy75 Member
    By the time you've bought a router, jig and anything else you might need just for this one job it'd prob work out the same as getting someone in to do the cuts, I'm all for having a go at stuff but when it's the finished job you'll be looking at everyday sometimes it pays to call in the professionals
    Jord86 and Astramax like this.
  11. longboat
    longboat Well-Known Member
    He basically makes it look more complicated than it basically is.
    Basically.
  12. kitfit1
    He does to be honest, he also should have marked the male joint from underneath. The worst thing though is the finished joint itself.............................it looked terrible in my mind. No way could i ever even think of leaving a fit with a joint that bad.
    longboat likes this.
  13. longboat
    I was cringing as soon as he made the first cut. The distinctive hight frequency chatter a dull bit emits was made even worse when he just carried on regardless. The join did indeed look pants, and no wonder.
    He said the worktop measured 615, more likely it was 616, but anyway, I'm sure the jig he used has a marker slot for that exact size, so why all the faffing about with the set square on the face of the female cut when checking the two tops for alignment?
    Pencil marks everywhere?
    Granted, it was a 'how to' exercise. I'd love to witness his methods when tackling a gloss black top and his pencil won't work.
  14. CGN
    CGN Well-Known Member
    Agree mate, 10mm masons mitre def way to go.
  15. Most customers I've ever done a full miter for actually love it as the butchers block runs Through and if done well and sanded correctly you shouldnt see a join, I personally would always try to butt joint solid wood tops as they are prone to movement and a masons miter is most susceptible to opening up
  16. CGN
    Yep...can't stand animals. There was this one time when I fed goldfish to my Rottweiler...
    WillyEckerslike likes this.
  17. CGN
    That's most nights...i always over do it :)
