IMI Powermax 155
Discussion in 'Plumbers' Talk' started by NikT, Jul 8, 2006.
  1. NikT
    NikT New Member
    I have an IMI powermax 155 which is 9 years old. It has started to light for a few minutes, makes a rattle and then cuts out before reaching temperature. A friend who has the same type of boiler and lives over the road has checked it over. He is a heating engineer. He thinks the internal baffles are distorted and restricting airflow.
    Has anybody out there come across this fault before we dismantle the boiler?
    How can I contact IMI waterheating? The phone numbers I have tried are NU.
    Many thanks for any help.
  2. Onetap
    Onetap New Member
    Since it seems no-one else going to answer...
    Powermax boilers were alter made by Range and condensing high efficiency Powermax boilers are still made by Potterton/Baxi. I don't know how the IMI models differed from later versions.
    Baxi/Potterton are on 0870 606 0780. They may be able to help you.
  3. NikT
    NikT New Member
    Many thanks for your reply Onetap.
  4. I understand baxi/potty took over the Range boilers and provide support ( spare parts and tech advice ).
    The burnt out baffles is a common problem with your model, probably exacerbated when its not serviced regularly.
    Tony
