Improving pressure in direct heating installation
Discussion in 'Plumbers' Talk' started by Ricardo Da Silva, Jan 24, 2020.
  1. Ricardo Da Silva
    Ricardo Da Silva New Member
    My flat suffers from poor mains pressure and we have a direct heat setup with combi boiler.
    The boiler is rated up to 3Bar, so I was thinking of installing a cold water tank to feed a twin pump supply cold and into the boiler for hot (both 15mm).
    My questions are
    - Is this a feasible setup
    - Can I use a single 28mm feed from the tank to a double 15mm manifold into the pump or should I install two 22mm/15mm feed pipes from the tank instead.
    Thank you in advance for any help you can offer.
