In need of help
Discussion in 'Eco Talk' started by masterdiy, Sep 20, 2018.
  1. masterdiy
    masterdiy Active Member
    We have a long internal hallway 10 mts, with 6 doors off, & 1 door each end, with glass in.
    At present we have 2 sunken spot lights in the ceiling for lighting. (equally spaced)
    These 2 lights are controlled by 2, 2way light switches.
    So need some thoughts on replacing the lights, something different.
  2. Pollowick
    Pollowick Well-Known Member
    I forget who makes it, although my local Electric Center sells it.
    Quadrant and Flat Aluminium Extrusion designed to taken the strip LEDs. Run a length along the ceiling on each side, fit with LED strip in your chosen White you can have even lighting all the way down!
    masterdiy and DIY womble like this.
  3. DIY womble
    DIY womble Active Member
    If you are happy with polls suggestion as you have high ceilings you could mount them on a dado rail , and possibly remove the spots and replace with hanging baskets if your not stretching to an overskim or matching the artex
  4. KIAB
    KIAB Well-Known Member
    First job, skim that artex, then consider Polls suggestion, maybe in cool white.
    [​IMG]
    masterdiy likes this.
  5. Pollowick
    Exactly what I was thinking!
    masterdiy and KIAB like this.
  6. DIYDave.
    DIYDave. Well-Known Member
    2 downlights in that hall will never provide sufficient light, must be gloomy in there, that Artex won’t cheer up that atmosphere either :eek:
    Heaping on more bad news ...... those old stylie reflector lamps look stupid tbh
    Rip out fittings, buy new, modern looking downlights, fire rated ‘cans’, you may not need fire rated but their generally better quality than cheapo ‘pressed’ fittings. Fit quality LED GU10 lamps - Integral Classic Glass are very good, cool, warm, dimmable, all available
    Yeah I realise it means cutting more holes, working out where joists are, possibly no access from above, getting cables through, etc
    But in the scheme of things, you’re getting that ceiling skimmed flat so it’s a perfect time to upgrade lighting - it’s gonna look fantastic :)
