In-wall 5v charger?
Discussion in 'Electricians' Talk' started by RoyWalker, Jun 28, 2021.
  1. RoyWalker
    RoyWalker New Member
    Hi all,
    I'm having some work done at my house and I'm thinking about wall mounting a tablet near our front door to display home information and control lights etc.
    I've been thinking about how best to power it, and ideally I think a 5v usb charger of some description which is recessed into the wall would be the neatest option - as I could then mount the tablet over the front of it to hide it - but would be able to access it if needed.
    I'd prefer not to have cables / plugs on show - but I'm not sure if such an item exists... has anyone seen a solution that would meet any required regs, that would result in the 5v usb connector not protruding past the 'face' of the wall?
    Thanks!
  2. RolandK
    RolandK Screwfix Select
    There are such things like the grid module
    From MK Logic Plus USB Socket. Check that one out or similar ones out there. Not sure if they are continuously rated though to stay charging all the time?
  3. Bazza
    Bazza Screwfix Select
    Here’s the MK one and the one that I would install CLICK
    LAP do a similar one. It may be cheaper for a reason though… CLICK
    you’ll need a suitable euro module plate too.
  4. RoyWalker
    Thanks both, I'll take a look into those.
    Good point made about the constant charge.. hadn't thought about that!
  5. CraigMcK
    CraigMcK Screwfix Select
    If you don’t want cables look at some wireless charging options mounted on the wall. A magnetic case will remove fixings/brackets too
  6. The Happy Builder
    Is there a tablet with a USB on the back of it rather than the bottom?
  7. Comlec
    Comlec Screwfix Select
    Might be of interest wall mount
