Increase distance BT socket to router.
Discussion in 'Tech Talk' started by RegB, Oct 30, 2023.
  1. RegB
    RegB Active Member
    My router seems to have rather a limited WiFi range. I have BT socket -> ADSL microfilter -> landline & router. What do I need (longer cable?) to get the router say 10m from the filter rather than the current approx. 1m? This is for better WiFi connectivity throughout the house, rather than just in theback rooms.
  2. Abbadon2001
    Abbadon2001 Screwfix Select
    Ideally you want to scrap the filter, and get a mastersocket fitted which has an unfiltered output, ideally one internal and one external, giving future options. From the internal extension output, you run solid core ethernet cable for an ADSL extension, to your chosen location. Then install an RJ11 socket at chosen location, connect the solid core ethernet to that socket, then connect router to the socket using your broadband router cable.
    You can reduce costs if desired by fitting an RJ11 to the ethernet cable and plugging it directly in, but the socket is a nicer solution. Similarly, you can get a double output faceplate from BT, which wont offer the neater internal solution, and plug a long adsl cable in to it - but solid core ethernet cable is a better conductor over long distances, so will be a better result.
    Removing the filter removes a source of interference and degradation, so a big plus.
  3. RegB
    RegB Active Member
  4. RegB
    RegB Active Member
    I ask that because simple and works better than it does now is much better, 'cos at the moment I am not very physically able at all due to being in plaster.
  5. Bazza-spark
    Bazza-spark Screwfix Select
  6. RegB
    RegB Active Member
  7. Bazza-spark
  8. RegB
    RegB Active Member
  9. I am thinking that if this does not prove satisfactory in improving the wi-fi signal a wi-fi repeater or a wi-fi power-line adapter might be worth considering. But if the router has below par wi-fi performance in your particular property I'd actually be looking at replacing that first.
    Obviously these are more expensive solutions than simply adding an extension cable to the router.
    Useful tips:-
    https://support.microsoft.com/en-us...-network-d28bf4e4-cf8c-e66f-efab-4b098459f298
  10. FlyByNight
    FlyByNight Screwfix Select
    How much? That is a rip off ...
    For basic cables in future, look at KENABLE https://www.kenable.co.uk/en/search?controller=search&poscats=0&s=vdsl+cables a 10m cable £1.99 and of same or better quality. They are also on ebay, where prices are a little more but include P&P.
    Tricky Dicky and Abbadon2001 like this.
  11. Abbadon2001
    My proposal would give the best improvement without buying new equipment or routers, and overall would be pretty cheap. Yes ADSL extension will work, but those filters are garbage and always fail in the end - id recommend buying a new filter and changing that too, if you insist on keeping it.
  12. FlyByNight
    Following my above comment - Kenable is a small family business, about 20 years old that was started in their garage. And they still offer great service on many styles of cables, phone, networking, video &c along with various accessories. And their prices are always sensible. I use some of their HDMI cables - no issues on quality.
  13. FlyByNight
    The best solution would be to run a 10 or 15m Ethernet patch lead to a new WAP - not the cheapest but proably just as easy as moving the hub - plus any extra internal pick-up of moise will be minimised.
  14. Abbadon2001
    yes that may also be a solution - id go for a mesh if you were going to spend money, but in the case of my mothers place, we got a very good improvement by moving the router near to ground floor ceiling and in to middle of the house, using my recommended method.
  15. RegB
    RegB Active Member
    So £7 from the Amazon seller PLUS £5 delivery = £12. £5 from the above source (Royal Mail 2nd. class), or £6.50 with RoyalMail first class delivery.
    How does one know that the cable is "the same or better quality", I wonder?
  16. FlyByNight
    And from Kenable £1.93 + 0.89p delivery £2.82
    Better? Experience with plenty of cables from various sources.
  17. RegB
    RegB Active Member
    I see. So not necessarily these specific cables. When the RGB Networks one comes, I will look at it, since Amazon would not cancel the order, even though it had not yet been dispatched, and compare it with the Kenable one, which I also ordered. I would guess they're both made in the PRC, but one's round, one's flat.
    As for the cost from Kenable (item 000638), the cable's £2.29 including, the cheapest delivery is Royal Mail 2nd. class at £2.63 for a total of £4.92, although (as previously mentioned) I selected Royal Mail 1st. class, giving a total of £6.48.
    I'll let you know!
