This further to my last thread but same lines . I have a zanusi induction hob Zitn643k and zanusi double oven zkcna4ki to install. The wiring instructions are poor . Would the attached be correct .Thanks 45a mcb consumer unit-10mm cable-45a dual connection plate 6mm cable- 13amp fused switch-6mm- double oven 6mm cable-30amp fused switch-6mm-hob
What size is the oven and hob? The normal setup would be 32 amp protecting 6mm twin and earth to a twin outlet plate feeding both.
Are you sure a 5.3kw oven says connect to a 13 amp spur? 32 amp mcb/rcbo- 6mm cable- to double outlet plate to feed both, that's it.
That’s what I thought until I saw the installation guide for the oven which also said use 2.5 I tried to load a pic but won’t let me . So my 45mcb is fine on 10mm cable upto a 45a wall switch then just put dual outlet wit the hob and oven no other fuses between
Mines up and running now 45rcd 10mm cable to 45acooker switch Then 10mm to dual split 6mm to hob 6mm to fused spur then 6mm to oven No issues so far but sure someone will say not right
