Hi I’m looking to use an infill drain cover to hide the drain in the patio. The current drain cover is on a 45 degree angle to the house and the drain shaft is on an angle. Because the drain shaft is a rectangle brick shaft (instead of circular) I can’t just adjust the angle of the new drain cover. Setting the infill drain cover on an angle creates a lot of extra cutting of slabs. Any suggestions or tips anyone??
