installing a new socket off a spur
Discussion in 'Electricians' Talk' started by ptatty, Apr 25, 2006.
  1. ptatty
    ptatty New Member
    My electric shower is currently running of a spur, however I have just installed underfloor heating and need to get another power feed to run this. The power feed to the shower is coming off a spur.Can I run the shower wire into a box and split it so that I get two power feeds one for the shower and one for underfloor heating. If so what type of box do I need to run this into.
    Need Help
  2. daveamyles
    daveamyles New Member
    No is the answer you cannot touch the wiring for the shower for one im afraid part p.
  3. JP.
    JP. Screwfix Select
    into.
    Need Help
    Mate I don't like saying this and normally wouldn't. The shower you have is put in entirely the wrong way. My advice to you is do not touch it and call in a competent electrician to evaluate the situation. I say this with no reference to Part P, but this is prime example of a potentialy highly dangerous situation. Leave alone. JP.
  4. madmaz
    madmaz New Member
    Get someone in to check this out, i take it the shower supply is for a pump only otherwise you may be seriously overloading something.
  5. Kirby Castle
    Kirby Castle New Member
    JP, I know what you are saying with this, but it is possible that the "electric" shower may just be a power shower rather than an instantaneous electric.
    In saying this, however, you are absolutely right - he should get a spark in.
    Steve
  6. JP.
    JP. Screwfix Select
    Steve
    Thanks Steve for pointing that out. JP.
  7. Legal Sparrow
    Legal Sparrow New Member
    ptatty
    If you give some more info, perhaps someone will be able to assist.
    What type of electric shower is it?
    Where is this spur? (under the bath, in the cupboard on the landing?)
    Is the spur fused?
  8. gaz58
    gaz58 New Member
    Serious answers boys but with a name like ptatty (potato) this has to be a wind up
  9. plastic bertrand
    plastic bertrand Active Member
    Well I never, gaz he could be called Peter Tatty. ;)
  10. sinewave
    sinewave Screwfix Select
    7 Posts before someone shouts windup!
  11. ban-all-sheds
    ban-all-sheds New Member
    What does that mean, exactly?
