Installing Fence Post next to path
Discussion in 'Builders' Talk' started by CJASENG, May 15, 2019.
  1. CJASENG
    CJASENG Member
    I'd like to install 2 fence posts butted up next to a path in my garden as shown in the picture. From what I've seen mostly when you install fence posts the post sits centrally in a hole with the post mix equally surrounding it. Is it ok to offset the post in the hole to say only 20mm away from the path? You're obviously only going to get a small amount of post mix between the post and the path and the remainder of the mix on the other 3 edges of the post? Fence Post.jpg Fence Post 2.jpg
  2. ramseyman
    ramseyman Active Member
    Yes it will be fine. Undercut the hole the path side as much as you can
    KIAB likes this.
  3. CJASENG
    CJASENG Member
    Thanks, When you say undercut, do you mean dig out underneath the path?
  4. KIAB
    KIAB Well-Known Member
    Yes.
    Works better with concrete than postcrete.
    ramseyman likes this.
