installing linear drain
Discussion in 'Tilers' Talk' started by baracus, Oct 30, 2018.
  1. baracus
    baracus Member
    Hello,
    The floor of my wet room is currently 70mm insulation which is sitting 100mm below the finished floor level, I want to fit a linear drain and then screed the whole area ready for tiling.
    The linear drain stands on 4 legs that can be screwed down into the ground, should i just screw it into the insulation? I was thinking a sheet of cement might be a good solution to screw the drain in to?
    Does anyone have any advice?
