Any recommendations welcome!! We have a small house which has no room for a water tank and we don’t have gas. Need to get hot water to two sinks - kitchen & bathroom. Any recommendations on either instant hot water taps or instant water boilers Thanks in advance
Our hosts do these. Put one under the sink & one in bathroom. I have fitted a couple of these earlier models before & found them ok. Get a Lecy in to do the cable runs. https://www.screwfix.com/p/ariston-aures-electric-instant-water-heater-9-5kw/305fj
Thanks. If you say one under the sink & one in the bathroom, does that mean I can’t run both sinks of just one?
A family member had a quooker hot water thingy for Xmas, cylinder goes in the under sink cupboard and you fit a special tap.
Quote "If you say one under the sink & one in the bathroom, does that mean I can’t run both sinks of just one?" Depending where your second sink is. If its plumbed to go to both sinks then yes one would do. But you will need a shortish run. These heaters don't store water. If you need stored hot water go for the larger one. Ariston Undersink Water Heater 2kW 10Ltr (3248G)
Thank you for this. The bathroom sink will be on the back of the wall where the kitchen sink is. So should be ok run wise. I’ll have a look into the link. Thank you again
https://www.screwfix.com/p/ariston-undersink-water-heater-2kw-10ltr/3248g Don`t you need the unvented ticket to install these?
