Insulation around front door
Discussion in 'Getting Started FAQ' started by iltpf, Nov 15, 2018.
  1. iltpf
    iltpf New Member
    My front door is surrounded only by pretty thin wooden panels on either side and I can't imagine it's doing a very good job of keeping the cold out. I already sealed up the gaps between sections (in the right weather you could see sunlight through the joins!) with silicone, but I'm now thinking of putting up a second layer internally and having some kind of insulation in between the two. There'd be a good 4cm between the two layers - what sort of insulation could I be looking at putting in?
    Cheers!
  2. chippie244
    chippie244 Well-Known Member
    Jablite, Celotex, Kingspan, rockwool.
  3. CGN
    CGN Well-Known Member
    PIR type insulation is best. 100mm celotex would be ideal for starters.
