Integrated washing machine door hinges
Discussion in 'Kitchen Fitters' Talk' started by Tangoman, Oct 5, 2018.
  1. Tangoman
    Tangoman Active Member
    I've been given a Neff/Bosch W5440X0GB washing machine but without the hinges that attach to the covering door.
    Looking online I can get a replacement pack, but they're nearly £60 which is almost as much as the machine is worth!
    Anyone any experience with jerry-rigging something?
  2. KIAB
    KIAB Well-Known Member
    Even on Ebay they are £48 for the Bosch Door Hinge Kit 31845.
  3. Tangoman
    It's the 00610416 kit I think I need - that's a little bit more.
  4. KIAB
    :oops: Can't even cross reference correctly
    Bosch F2i Hinge Kit
  5. kitfit1
    kitfit1 Well-Known Member
    One of the main things you have to be aware of with Integrated washing machines is that that they are in no way "Integrated" at all. All of them are just free standing machines that happen to have hinges attached to them. Most hinges are the same from one manufacturer to the next. If i was you OP, go for the cheapest you can find and try them, chances are they will fit and work fine regardless of weather the machine is a Bosch or a Beko.
    WillyEckerslike likes this.
