Iroko edging.
Discussion in 'Kitchen Fitters' Talk' started by Atkani, Dec 16, 2006.
  1. Atkani
    Atkani New Member
    Hi. I need to edge a 48mm laminate top with an Iroko strip. What would be the best adhesive to use to get a good tidy & waterproof joint? The top is a black granite effect. Cheers.
  2. gardm1nt
    gardm1nt New Member
    Pu adhesive with clamps while it sets.
  3. jasonb
    jasonb New Member
    As Iroko contains a lot of natural oils you should clean the surface with acetone before glueing and a wipe with a damp cloth will help set off the PU glue.
    Jason
  4. Atkani
    Atkani New Member
    Cheers fellas. Where am I likely to pick up some acetone?
  5. jasonb
    jasonb New Member
    Nail varnish remover will do for a small job as long as its not the "acetone free" variety, otherwise look for your lacal fibreglass supplier. You will find that reclaimed acetone is less expensive than pure.
    Jason
  6. mr.kitchen
    mr.kitchen New Member
    i buy cellulose paint thinners by the gallon, its about £15 now, but does all those de-greasing jobs and lasts for ages. Got to be careful with it though.
