Is it too late?
Discussion in 'Painters' Talk' started by Graham Linton, Nov 25, 2021 at 1:08 AM.
  1. Graham Linton
    Graham Linton Member
    To paint outside?
    I want to paint a small porch, undercoat and gloss white but didn't know if the weather was too cold for the paint to dry. I am in Lancashire.
    Thanks
  2. Astramax
    Astramax Super Member
    Drying time is a problem at this time of year due to lower temperature, condensation and shorter days which can leave bloom on a gloss paint. Have a look into Zinsser Allcoat exterior gloss as can be used from 10 degrees.
  3. woodbutcherbower
    woodbutcherbower Well-Known Member
    I concur with Max. There’s also this;
  4. Graham Linton
    Thanks guys. Will leave it till spring then. Another job on the never-ending list.
