Is my sink leaking?
Discussion in 'Plumbers' Talk' started by robertpstubbs, Jun 23, 2020.
  1. robertpstubbs
    robertpstubbs Screwfix Select
  2. just pumps
    just pumps Screwfix Select
    What is going on there!
    All that carp and no floor!
  3. teabreak
    teabreak Screwfix Select
    Well ventilation is not a problem!;)
    masterdiy likes this.
  4. candoabitofmoststuff
    And the door hinges need adjusting!
    Cando
  5. Mr Rusty
    Mr Rusty Screwfix Select
    we really do need a bit more information! I would say probably not because the potatoes are not growing, but you may have a big mouse problem.
  6. METRO MARK
    METRO MARK Active Member
    Could be a very tidy Rat or other. Nice neat pile....
  7. METRO MARK
    Ah did the plumber use the correct washer on the U bend?
  8. robertpstubbs
    932408B6-75CB-45C8-99A4-71C90FEFAEC6.jpeg Since had a bit of wash down - not entirely intentionally. One of the nails holding the floor to the copper pipes gave way.
    candoabitofmoststuff likes this.
  9. Mike58
    Mike58 Screwfix Select
    Some pretty ropey water in your area - it has eaten the cupboard floor away!
  10. METRO MARK
    Probably a badly routed condense pipe from the boiler. Acid corrosion and all that
  11. masterdiy
    masterdiy Screwfix Select
    robertpstubbs, I suppose you don't need anyone to tell you, but.
    That whole floor needs lifting.
    Inspect & replace joists as ness.
    Inspect & replace any water pipes & electrical wiring as ness.
    Replace floor.
    Adjust the door hinges. (credit here must go to (candoabitofmoststuff)
  12. Mike58
    How can you know? they are hanging loose.
  13. masterdiy
    He didnt say they were hanging loose.
    He said..And the door hinges need adjusting!
  14. DIYDave.
    DIYDave. Screwfix Select
    Its a joke, a wind up, a bit of fun, a little tickle to celebrate the forum returning ......?
    Surely :confused: ?
    If not ......... the suggested leak is the least of your problems :eek:
    Mr Rusty likes this.
  15. Mike58
    Without them being fitted to a door, how can anyone say they need adjusting? The door they cam off might have been perfectly aligned.
  16. robertpstubbs
    What about the walls?
  17. robertpstubbs
  18. Mike58
    After effects of a post vindaloo gut explosion?
    And what would B-A-S say about the electrics?
    METRO MARK likes this.
  19. masterdiy
    They can fall down on their own.
    Its only the sockets & wires holding them up!!!o_O
    And chisel off the plaster before lifting the floor.
  20. robertpstubbs
    I wonder what the cable with the red tape is for.
