hi, I've recently had a bathroom tiled and noticed the edging strip used sticks out over the edge of the tiles by 2 or 3 mm. it's particular notiavble in the external corners where the litres profuse quick a bit. is the normal or has my tiler used the wrong depth edging strip?
Please post some pictures so we can see. Oh! and give your spell checker a kick up the backside at the same time. Trims do often protrude it depends on the look of the job whether it is acceptable.
Perhaps you meant "where the mitres protrude quite a bit" 2-3mm is too much I'd say. Ideally should be flush. Trims typically come in 2mm increments (6mm, 8mm, 10mm depth) and with a suitable amount of adhesive, should be able to get it flush more or less. Sounds like he used 10mm trims with 8mm tiles?
