Is replacement of a Broken Junction Box notifiable?
Discussion in 'Getting Started FAQ' started by mitrekab, Jun 29, 2020.
  1. mitrekab
    mitrekab New Member
    I have been clearing out my cellar making some space to do some homebrewing. Noticed a junction box with its lid(cover) sagging pushed the lib back up and it fell off. Looking ta the center screw the center screw is cracked so half is in and half is out.
    Am I allowed to switch of the electric to the ring (I have traced the wires back across the cellar celling to the consumer unit) and put a new junction box in? Or is this a step up from moving a socket so notifiable and thus means only a qualified sparky can do it.
    I could just squirt some araldite in the screw hole and put the screw back in but that seems a little shabby, how would a future electrician get in to the box. Would a future electrician need to open the box, been here 13 years and never had an electrician in the house ?
  2. dobbie
    dobbie Screwfix Select
    mitrekab and Hans_25 like this.
  3. Hans_25
    Hans_25 Screwfix Select
    If it were me I'd simply replace it.
    mitrekab likes this.
  4. mitrekab
    mitrekab New Member
    Thanks, was going to as it seems making safe something has got to be better than leaving or bodging.
    Interesting you say incase I board the ceiling. I don't like all the steam going up to where all the wires and the junction box is so was looking at doing something.
  5. rene moris
    rene moris New Member
    As we all know in the city like dubai we all need electrician. For inspection and testing you need a professional electric worker. if you need to upgrade lighting system you should follow electrician dubai . for cctv installing you need a electrician too. electrical panel update should be done with skilled and experienced electrician .
  6. mitrekab
    mitrekab New Member
    Sorry not in Dubai, do they have screwfix in Dubai ?
  7. METRO MARK
    METRO MARK Active Member
    You not seen the diamond encrusted Solid Gold VDE sparkey set yet?............ EXPORT only version
    Pity they don't WagoBoxes in Gold....Only RED Black Grey ETC
  8. Tuxornot
    Tuxornot Active Member
    But do they sell a gold plated, diamond encrusted torque driver and solid gold socket set ? if not then the catalogues a bit naff.
    You can convert wago's to gold colour with some gold leaf, a task often left to the apprentice ;)
  9. Hans_25
    Don't forget to do the insides as well :p
  10. Tuxornot
    You don't see the inside so use brass leaf, cheaper :p
  11. METRO MARK
    Graphite spray is quicker & Cheaper
    Would the Junction Now be notifiable to the house insurance company as a expensive item :oops:
    Tuxornot likes this.
  12. Tuxornot
    You only notify the insurance company if its embellished in precious stones :D
  13. METRO MARK
    But what about a JB that are studded with precious stones. EH JB that are surface mounted to show off the bling.
    Easy to install
    Loads of $$
  14. Tuxornot
    Very hard surface mounting them because there's a shortage of gold screws, unless you used screw gold caps. As you can tell, a lot of thought has gone into this, part of my get rich scheme if I ever end up in Dubai :p
  15. METRO MARK
    They wont see the mounting screws, they inside the JB...use SF gold screw they never know
    Make up special range for superstars with too much dosh wannabee rappers like Snoop doggy Doo they buy stuff like this
  16. Tuxornot
    Who ??? Snoop doggy Doo ? No wonder I'm skint, I'm mixing with the wrong sort of music people... classical, hinge and bracket...... sheesh :)
