Is there a reason why my builder has only put 1 screw in this freezer?
Discussion in 'Builders' Talk' started by GeorgeOKelly, Jun 13, 2024.
  1. GeorgeOKelly
    GeorgeOKelly New Member
  2. DBCDIY
    DBCDIY Screwfix Select
    Can't think of any technical reason.
    Maybe:
    1)Because he's not a kitchen fitter?
    2)Had his tea break and forgot?
    3)Ran out of screws?
    4)To save you time when you need to replace it?
    Whatever the reason hopefully all you need to do to rectify the problem is to just pop a couple of screws in - where the holes are in the steel plate - and 'chill out' - by defrosting your freezer :)
    Bob Rathbone likes this.
  3. Bob Rathbone
    Bob Rathbone Screwfix Select
    If everything else that the builder did meets your expectations you are very fortunate to have found that builder, I would forget about this and just put in another screw or two.
    teabreak likes this.
  4. RegB
    RegB Active Member
    Don't know, but what's off level (or is it both the worktop and the freezer?
    arrow likes this.
  5. arrow
    arrow Screwfix Select
    Was going to post the same thing, somethings out.
  6. Rulland
    Rulland Screwfix Select
    Your freezer also needs defrosting:p
  7. Derevonian
    Derevonian New Member
    Have the screws came out and fall off?
  8. GeorgeOKelly
    I don’t think so since there is no hole.
