We prefer a matt finish on internal woodwork. Have tried Leyland oil based eggshell from yours truly, but it's still too shiny. However, being oil based, it's easy to apply and lay off to a smooth finish. Tried Leyland acrylic eggshell. I've found it difficult to apply - laying off is virtually impossible so the surface finish is nowhere near as smooth as an oil based paint. However, it is far less shiny then the oil based equivalent eggshell. So how can I get an oil based paint with a flatter finish than eggshell (other than post application sandpapering!), or alternatively is there an acrylic based paint suitable for internal woodwork that lays off easily?
Dulux Diamond Eggshell would be a good choice, waterbase paint has a lesser sheen than oilbase by circa 20%. Use Zinsser Bullseye 123 as a primer/undercoat should you go this route.
