Is this a bodge?
Discussion in 'Other Trades Talk' started by Davros1976, Sep 8, 2019.
  1. Davros1976
    Davros1976 New Member
    Had a new front door and frame fitted. It looks to me as the frame was about 20mm short and been bodged with a packer that's a different colour. It looks odd on the white interior as well. The door mechanism has been moved down as well. Is this standard practice?
  2. KIAB
    KIAB Well-Known Member
    A bit of a hash up,as for moving lock, NO.
  3. Davros1976
    So it's acceptable to have an obvious cut out in the frame that shouldn't have been there in the first place as seen in picture 2?
  4. koolpc
    koolpc Well-Known Member
    Yikes!
  5. gadget man
    gadget man Well-Known Member
  6. jonathanc
    jonathanc Active Member
    Looks like the striker plate has slipped down - i’d Expect it to be central on the lock and it looks low. As to the spacers: not sure. They “might” be needed to adapt the Ali threshold profile onto the frame. Black might be closest they have to anthracite which is outside colour
    So it may be
    A) a quick adjust on the striker plate and
    B) failure of the salesman to explain about the black blocks
