Is this an asbestos cement or cast iron soil pipe?
Discussion in 'Plumbers' Talk' started by I2278, Jan 18, 2019.
  1. I2278
    I2278 New Member
    I have attached pictures of my soil pipe, just wanted to know if it’s a cast iron or asbestos cement soil pipe. It’s an internal soil pipe in a block of flats if that helps.
    There is currently one toilet attached to this soil pipe, the branch off the soil pipe can be seen in the pictures, I would like to install a second toilet in the bathroom which is adjacent to the toilet room, how would I go about doing this, i.e. is it possible to change the angle the branch protrudes from the soil pipe at?
  2. Wayners
    Wayners Well-Known Member
    Stick shavings foam on and drill through it a little. Be obvious if it's asbestos or iron
  3. rogerk101
    rogerk101 Well-Known Member
    You should be able to hear the difference when tapping them with something like a screwdriver or small hammer. If the sound is a dull thud, then it's likely to be cement based. If it's more of a metallic sound then it's likely to be cast iron.
    Heat likes this.
  4. Wayners
    fridge magnet could be put to good use and will prove iron or not
    Heat likes this.
  5. goldenboy
    goldenboy Well-Known Member
    Magnet surely is the best way.
  6. teabreak
    teabreak Well-Known Member
    Odd connectors for either iron or asbestos might even be plastic!
